Old 03-08-2007, 12:14 AM   #2 (permalink)
Justintoxicated
Justintoxicated's Avatar
Re: Multi channel or 2 amps?
Originally Posted by shdw03
Audio gurus. Debating to either get a 5/6 channel amp for Full system or just get one 4 channel and one mono amp? I was looking at the memphis belle amp. Any input appreciated.
Depends what you want to do really.
single amp is less to mount and makes a cleaner install.
Multiple amps makes your system a little more versatile. For instance I want to change my sub I don't have to buy a differnet 5 channel amp. or I buy a sub that needs so much power I can't find a 5 channel amp and need to keep the existing one and add a second amp anyways. or I change my components and they need a little more power so I need to buy new amps, or bridge 2 of the channels.
If you know the amp works with all your components, and subs, it fits the dimensions you need, and you will not be swapping or upgrading later. Then by all means go for it.
Yes, I hear/read memphis makes good amps.
