Re: Want to hook up a bass tube
Ign. lead are lead (wire or fuse) that only has power when the ign. is on.
Power bass tube have a built in amp, you hook it up like a normal amp.
Power line goes to battery, ign. lead goes to an ign. source (only has power when ign. is on). That way when you shut the truck off, the amp. inside the bass tube goes off and not drain your battery. Like bestatchess stated, if you don't have an ign lead than use a relay in line with your power line.
