Old 03-11-2007, 01:47 PM   #36 (permalink)
leukus
Re: 10 MINUTE SEAT LIFT! (Pics)
Originally Posted by P-Dizzle
Easy seat lift mod. Takes less than 10 minutes and costs under $10. I used 1" round 25mm thick anti-skid pads, 25mm rubber grommets, and 5/8" bolts. I picked the skid pads up at Home Depot and gained 1.5" of height at the front of the seats and the seats still latch. You could add washers if you need to go higher but the seats may not latch. This will allow for more room for your up/down firing enclosures. Lifting the front of the seat will also allow for forward facing 10's. Mounting depth will be around 10" in the King Cab depending on the magnet diameter.
i found the rubber gromets but what department was the anti skid pads in?
Thanks
leukus is offline   Reply With Quote
