Originally Posted by ruauman2
If you don't take my suggestion above, you may not fix your issue and end up spraying a bunch of crap in your truck.
Good luck, your gonna need it.
that 'recirculate' thing you're talking about is related to MAX AC versus regular AC... my 07 Titan has MAX only, which means it recirculates air in the cabin and doesn't draw in the hot air from the outside. Or, at least, that's what I hear.
Now, in the post you referenced... a fella said the same thing that I did about lysol, but he SOMEHOW managed to get the Titan to take in air from the outside, maybe he was using the vent rather than the AC. Maybe they had a regular AC setting on the older models, not sure.
Would someone try both of these methods out? I'd like to know.
