Re: Transmission Flush / Fluid Questions
The best way to do is to have a dealer with a flush machine. They run some cheap ATF through to flush, then fill it with the J.
To approximate a flush by yourself, you can disconnect and drain through the line (return - I think) from the ATF cooler while filling (as described in the service manual), but I would recommend having it done by a dealer with a flush machine.
