Re: Post pictures of your Wheels!
Originally Posted by wssboard18
What is the back spacing on these wheels and do they stick out from the wheel wells? thanks
The True Backspacing on these wheels is 4" not 4.5". The specs on these are 17X8 4.5" BS & Zero Offset. Stock wheels have a +25 MM (one inch) offset. A wheel with zero offset has a backspace of 1/2 the wheel width; so a 8" wide wheel with zero offset has a backspace of 4". Positive offset shifts width to the inside of the wheel, so the amount of offset is added to the backspace.
Yes they do stick out a tad but not much at all and have no rubbing issues. Mine are basically 33's with a leveling kit. Here is a pic of them and har far they stick out. I hope this helps.
It's a Titan!!!
