Old 03-30-2007, 10:51 PM   #27 (permalink)
SKEET
Re: Popping noise from front end
Originally Posted by Shane06fl
I thought it was the front too and could feel it in my feet. For the life of I couldn't figure it out. I called up the service scheduler at the dealership and asked him if he had any other problems like this so I could fix it myself (I don't mind) he said to look at the two bolts that hold the rear trany mount to the trany.WHAT? well sure'nuf one of the bolts had backed out and was jammed on the cross member. I called him back and said bring it in now if I could. I did, took the tech about 20 minutes to replace both bolts. Then he spent another 45 minutes checking every nut and bolt he could find under there. Then he said he didn't like Nissan's POS axle vent and installed new fitting and put a hose to it. Told me to install a small fuel filter to help keep dirt out. There is a do it yourself on the same fix here on TT. BTW that valve is not a check valve, it is open hole right to the axle.
Sorry about that, check you trany mount bolts where the trany and TC meet.
I checked my tranny bolts and they're tight.I don't know what else to look for.
SKEET is offline   Reply With Quote
