Old 04-01-2007, 12:26 PM   #6 (permalink)
Smoke05
Smoke05's Avatar
Re: Anyone with airbag sensor knowledge??
Originally Posted by cpaul
You have a front impact sensor located right behind the grill just under the hoodlatch. make sure that it is there(have seen bodyshops forget to put them back), make sure it is securely plugged up(remove plug and check for bent pins,seen this too) make sure the harness is not damaged. That harness is part of the engine room harness and that part of the SRS system is shielded. If it is damaged or pinched Nissan does not recomend that it is repaired just replaced due to the sensitive nature of the shielded circuit. Before you start poking around on this disconnect the negative battery cable for about 10 min to discharge the system. Also this is highly recomended if you do any welding on the truck because you CAN set off the airbags.
OK I think this is what happened. The owner of the body shop mentioned the harness needing to be replaced because it could not be spliced. What gets me is that the light was not lit when I dropped it off and they found this after it was all put back together.
Smoke05 is offline   Reply With Quote
