Old 04-05-2007, 07:51 AM   #296 (permalink)
TallTexan
TallTexan's Avatar
Re: Here's # of Rear Diff Failures Reported
Originally Posted by Red Ryder
new here... reading some of the symptoms of the rear problems... are they VERY obvious? humming and such. I have 19k on my 2005 KC with a locking rear and never thought about it. I did have the brake issue, after I towed a bass boat through the mountains. dealer replaced and they are fine but have not needed to tow heavy since.
My symptoms were a whinning sound around 50-60 mph which stops when you let off the gas but happens again when you step back on the gas. When I check the oil in the diff, it is a dark color rather than the clear pink oil they put in. Check the inside of your wheels to see if you have any seal leaks. Two of mine had seal leaks. Others have had metal rattling sounds all the way up to a total lock up.
Robert Louis Stevenson
