Old 04-05-2007, 09:26 AM   #5 (permalink)
xterraintx
xterraintx's Avatar
Re: Lights going out on A/C???
OK, kind of the same problem
I keep blowing the 10amp fuse under the hood for the AC and other knob lights. The dealer can't find the problem...said the harness would need replacing at like $650 parts and a lot of labor.
Is there a way to see if my dimmer switch might be shorting? If I remove it then none of the dash lights work
Maybe I can short the wires to the switch to bypass it in order to check? There are 3 wire connections on it. The replacement switch is $68 I'd hate to buy a replacement if mine is good.
APPRECIATE any HELP !!!!
xterraintx is offline   Reply With Quote
