i like Kartman removed mine. best thing i've ever done to my truck. i also have the same coilovers as kartman so the higher spring rate makes up for not having the swaybar somewhat so an increase in body lean is a little bit more noticeable, however if one were to take off the sway bar in front without having coilovers with a higher spring rate, you'll perhaps think you're going to roll over...
all depends really on what purpose your truck is going to serve you. i absolutely love the way it handles now that it is off!
