Old 04-09-2007, 06:56 AM   #4 (permalink)
spalind
Re: Gears, spools, lockers, axles now developed!!
Originally Posted by John Harden
Interesting. I wasn't aware that the axle, differentials, gears and locker were identical between the Titan, Frontier and Xterra. I kind of assumed the Fronty and X were very similiar if not the same, but sorta figured the Titan components were significantly larger.
Even if they are different and won't bolt on, it is still good to see someone working with Nissan and gear manufacturers on replacement components for our vehicles.
Now, let's hope it carries over to the Titan!!
Regards,
John
The Titan rearend is identical to that carried by the OR and I believe SE models Xterra's...same weird D44 variant....Here is Dave's latest post...
"GREAT NEWS"
The diff gears are in the works right now! I will post more at a later date. I started these because I needed them for my Xterraracer program. I requested 4.88, 5.13 and 5.38 ratios to start. I have another vender building rear spools and axles for the Nissan D44 housing. I am still working on the front LSD w/4 spiders and inner CVs.
I will more than likely bring out some longer tubular arms as a kit with longer axle shafts and tie rods. Note; these won't be for my racer, but because "X" owners would like the option. This mod may warrant molding some 3" wider glass fenders too.
Believe me when these are ready to hit the market everyone on these "X" related sites will know!!!
spalind is offline   Reply With Quote
