Old 04-09-2007, 12:53 PM   #8 (permalink)
spalind
Re: Gears, spools, lockers, axles now developed!!
Most recent info on what is being developed....
"We had thought that the R180A was going to be the answer but we found it had a different bolt pattern for the ring gear and the pinion length was wrong. It seams the only thing that was the same was the discription R180A. The manufacture I am working with has decided to build the stuff. This may cause us to only get one option for front diffs but, it will be the 4 spider gear clutch type locker.
I also found out that the Titan front end is not the same as the X like we all had thought. The Titan rear is the same, just wider axle tubes with longer axles. So I think we will end up with several options for the rear, since the market is Titan driven."
spalind is offline   Reply With Quote
