Re: Installing Deaver Question?
I did my install with the leaves in place, but if I was to do it again with air tools, I might just pull off the spring and do the mini-pak install on the bench.
Getting the overload off is easy, it takes a little more hassle to get the pak on afterwards...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
