Originally Posted by MA-titan
Just had my front diff replaced last week and noiticed last night that the reverse lights are not working. The relay under the hood is fine, bulbs are fine now what? Is there a fuse not listed in the fuse panel? I don't think there is need to disconnect anything under the truck to replace the front diff or is there? Help!
1. Somewhere the harness has grounded on the reverse wire. It could have been nicked I imagine.
or
2. The signal when you put it into reverse from the shifter is not working and not completing the circuit.
Just curious if you put it in reverse and connected a tester to your trailer wiring harness what would happen...
