Re: warped rotors
Originally Posted by Nissan Mike
Nissan will no longer do a complete update again after this has been done initally.You rotors are still covered under warranty 3-36 for rear but the warranty for the front rotors for jutter has been extended to 3 yrs unlimited mileage.If rotors are machined or replaced under warranty the pads are included.If it is just worn out pads,unfortunately you're an owner.
very true.
its hard to wear out pads in 6500 miles with normal driving and braking.
05 LE Crew Cab Smoke OR 4x4
airbox mod with K&N
Scangage2/blendmount
Roadmaster Active Suspension
NCD leveling kit installed 3/10/09 Thanks Adam!!
MVP Titan sticker on 3rd brake light.
2º Timing advance, Thanks John! 11/14/09
future mods - JBA Evol  , Injen Powerflow, and more
