Re: Here's # of Rear Diff Failures Reported
check the seals are not leaking behind the rear tires. Drive at different speeds and see if you have a whine comming from the differential. Check passenger side front carpet for water leakage from the a/c. Check the owners papers to see if the latest brake mods have been done by Nissan. You still have lots of warranty left so you should be o.k. After you purchase, read all the posts here regarding Titan problems and you will know what to look for. Good luck.
Robert Louis Stevenson
