Old 05-03-2007, 04:38 PM   #1 (permalink)
pungohboy
04 XE KC Brake controller install
Ok I have searched and found some info about the 04 XE's not having the factory pigtail connector under the dash, however I have also found a post here that is by Carter Which says the wires are behind the kick panel which I do see there is a place where it looks like a plug can plug in with 3 pins. My question is does anyone know if there is a wire harness you can get from a dealer that plugs into that that will allow the pigtail connection. Also it is only 3 pin I am assuming maby no ground? I have a prodigy and was about to buy the titan connector but i do have the generic connector I can splice in if need be. I just need to know where to get started. If anyone knows if there is something that can plug into that white connector please let me know. I might try to get to the dealer tomorrow and see if they can show me a diagram maby of a SE to see if i can see what plugs into that spot.
Thanks for your help. This is my first Titan I bought it 2 days ago and need to tow my 7x16 enclosed trailer so just trying to get the prodigy hooked up. I will pick up the relays at the dealer tomorrow also.
2004 Titan XE KC 4x4 OR Flowmaster, Airbox Mod
2006 Polaris Sportsman 700EFI AMSOIL AFF 0w40 Polaris/Warn 2500lb winch,Black ITP C-Series Type 7 with 27inch Bi-Tri Claws, Front Brush guard, Rear Bumper, Front&Rear rack extender, AMSOIL Air Filter, Moose Heated Grips/Throttle, 3 Headlight mod, Overflow bottle snorkle.
EAST COAST ATV RIDERS
http://ecatvr.com
pungohboy is offline   Reply With Quote
