Originally Posted by P-Dizzle
Outside the truck?
2nd page 4th pic.. Topper Lights?
Cool let us know how the HO Alt install I believe you need to use a hose wrench on something (Power steering?) to do the install. I'd like to know how hard it is.
Working with any 0ga is a ***** especialy when it is oversized. I had a hard time even with the Knu Wire, it would not fit in the ANL fuse holders, well it would first try if you were extreamly careful but thats it and it was a really tight fit at that.
I did my tweeters the same way, only I could not use wood I had to use Thin Carb board (even cardboard from a box was too thick) due to the size of the Iridium Tweeter's dome) Would have been difficult to counter sink lower than the dash as well. The stock grills keep the cardboard pressed in place and does not allow the tweeters to jump. Can't see them anyways so it works well. How is the imaging with those tweeters in the dash? Are they real directional?
Home Depo Sucks for specialty screws
