Old 05-07-2007, 11:17 AM   #15 (permalink)
54warrior
54warrior's Avatar
Re: is truetrac any good offroad?
Originally Posted by adavis99
Tru=Trac is an upgrade in every way, shape form for non-elocked titans...
Only concern is that if your diff blows up with the Tru-Trac in it...you might be out some $$$.
The tru trac does replace failure prone components in the diff although I know at least one person had their diff replaced with a tru-trac upgrade.
The Tru-Trac IS the differential, so if it goes, it won't be Nissan's parts/fault. There is the possibility that the ring gear could go, but they should still cover that. (I'm assuming this is what happened to the person you refer to?)
It, essentially, replaces the "guts" in the rear end, minus the ring/pinion gears. Note that the ring/pinion gears are not the weak links in our rear ends, it is the spider gears, which ARE replaced by the TruTrac.
Originally Posted by plumberemt
from what i've read it should not change gear ratios or the higher shift points when you are in tow mode. since the truetrac is a stronger unit than the oe it should take more towing abuse. it should also help at the boat ramp, if you are towing a boat. this is just my interpretation or what i've read here about TT (about 8-9 hrs my retinas are burnt!)
Correct, it WILL NOT change any of the gear ratio's because none of the gears are replaced by the TruTrac
As far as whether you have the "old weaker parts" plumberemt, you need to let us know what year/model you have. My basic understanding is that MOST 2006's do and ALL 2007's. All depends on whether you have BT/OR/Etc...
"The grass is always GREENER over the sh1t tank!"
