Originally Posted by tech12volt
This is the most accurate 240 dollar sub you find. Thats no bs. The sound is amazing.
There are things this sub does that 500 dollar subs cant do it. This is not a spl sub. It is pure sq.
BM's look like great subs, but if you want to hit the low notes I have to wonder how the TC1000 compares, more X-max in a sealed box, although X-max isn't everything. They are supposed to be almost the same, but I hear the BM has a little advantage ported supposedly between the TC 1000 and 2000 although less LINEAR X-max so I'm not sure if that holds up sealed, at least on the low notes.... To me having a huge X-max in a sealed box might be nice but only if it is absolutly Linear. Tech when are you going to try a TC sub...?
If I was going to pick something other my my 1000's in downfire I'd probably go for the BM (it's 2x as expensive though). Larger subs just won't fit.
I am imagining the BM as having the accuracy of my Assassin with the output of the TC1000.
