Old 05-08-2007, 06:56 AM   #1 (permalink)
54warrior
54warrior's Avatar
Tire Size/Odometer/Speedo Correction...
I see this being asked alot, so I thought I'd make a post that describes why changing to a larger size of tire also changes your speedometer and odometer readings. It also explains how to determine the "correction factor" which can be used to calculate how many miles you really did travel, or how fast you are really going.
I also showed the correct method for determining the circumference of a metric sized tire (ex. 245/75/17).
Maybe this could be made a sticky if you think it's helpful??
2005 Nissan Titan CC SE 4x4
The Following User Says Thank You to 54warrior For This Useful Post:
CL 8 2WD (01-03-2009)
