Re: Can's and Can not's of VKPro
Originally Posted by V8 TITAN
so can you run 91 octane one day with the chip, then take it out the next and run 87? or are you required to run 91 all the time?
Yes you would need to remove the module if you want to run 87. As long as the VK Pro is hook up to your ECU, 91 is a must.
Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
