Old 05-27-2007, 09:57 AM   #22 (permalink)
Steamguy
Steamguy's Avatar
Re: Fix the Tow Mode - please
Originally Posted by loufish
After reading these posts, I've come to realize this:
The 2004 Titans seem to have a problem keeping the T/C locked at moderate towing speeds, while the later Titans don't seem to share this same issue..
Now, some of the guys here have stated that the tranny temps will go up unless they manually downshift, that sounds like the T/C is unlocked because that's were the heat comes from. Are these trucks having a problem keeping the T/C locked, but the owners don't know it?
I think you're onto something here. I've found that using Tow Mode is useless in my early '04 because the torque converter just won't lock at all. When I DON'T use Tow Mode, but instead just keep it in 4, everything's happy. Torque converter stays locked, RPMs stay low if you give it just a little gas.
And here's another way that mine appears to be different: I can have mine just set to 4 (Manual mode) and it acts just like a regular automatic, where it will downshift if the RPMs are too low, or if you punch it.
There were a number of changes in about July of '04. I would now bet that the ECU/TCU were part of them.
Steamguy
