Originally Posted by Toomnymods
not talking bout spikes mark look at the 20mph area it is 60hp 80tq gain by adding uprev tune with drive by wire mod, i know the spikes dont show true hp thru the shift.. i dunno what the diffrence between STD and Sae corrected numbers are but i can show both if you want STD numbers are on average 10hp12tq less than SAE
Oh i see what you are saying, really nice gains down low man! I thought you were talking about the spikes....lol. SAE accounts for temps and humidity. In other words if it was 50 degrees outside STD would be way higher. But if it was 100outside your output would show way lower. I think SAE uses around 85 degrees as a base! Everyone should use SAE for a real world comparison that way you can't use cool air as an advatage or complain about how hot it is outside. SAE does the math for you...So what that mean's is.... if your STD numbers are 10hp less you are the new dyno king!
Lets see SAE !!!!
