Old 06-25-2007, 01:55 AM   #25 (permalink)
Fox Delta
Fox Delta's Avatar
Re: Welcome to the New Towing and Hauling Forum!
Originally Posted by Titan_Love
So I just installed air bags on my 06 Titan. Pretty cooll! I wanted to share what my step-son came up with. He was lloking for a place to run the intake valve for the bags. He had the idea to put a compression "T" so as to connect the two bags and fill them simultaneously. Better yet, he decided to run the intake valve through one of the screw holes for the license plate and ran it through there. You can barely notice it is there and all I have to do now is unscrew the cap and fill the bags through the valve in the license plate. I thought it was pretty ingenious.
Do the bags have a one-way valve on them?? That way when you corner and compress one side the air doesn't flow to the other side (back and forth like on a raft)?? I thought they were always seperated to prevent that unless part of the "nicer" kit. Sorry, I don't have a better understanding of the airbags - it just seems that if the manufacturer intended for the air lines to be connected it would be part of the setup from the beginning. Plus it would stink to lose the air pressure when needed the most.
2004 XE 4x4 CC OR
6" Pro Comp lift with SAW's
Deaver Springs in the Back with Bilsteins - thanks PRG!!
Bumpin Sub box and Sundown Amp thru Tech12Volts!!!
37x13.50/17 Toyo M/Ton Factory OR wheels
Cherry Bomb Extreme Exhaust
Fox Delta is offline   Reply With Quote
