Originally Posted by seniorgp
Want to ask if I'm reading this right. To go from Big Tow Mirror to a "Regular" mirror you need to stay within trim levels ie: LE to LE and SE to SE?
I have an LE with Big Tow mirrors and want to change to regular. Would an SE power, heat be a direct swap for an LE BT power heat and memory?
I know the mounting is a little different I just need to know if any electrical differences.
Thanks
The mounting is easy. Both mirrors will mount. Your problem is the electric connector. The LE models have a 10 wire plug and is black in color. The SE has a 5 wire plug and white in color. I dont think LE's come with regular mirrors.
