Old 07-01-2007, 05:44 PM   #1 (permalink)
FaintReality
7" kit questions
I plan to pick up an 08 titan SE 4x4 in the next couple days and am interested in the 7" CST kit.
First off, will the kit work on the 08's, or are there suspension differences?
Secondly, with the 7" lift up front and the 4" blocks in the rear, the truck will sit level?
I like the front stance to be a little higher, and would like the rear to sit a good 1 - 1.5" lower than the front. With this in mind, I was wondering if I can do the Deaver 2.5" mini pack and call it a day (no blocks)? Will I still be able to clear 35" tires?
Lastly, everything is included in the front to raise it the full 7" correct? I don't need the optional upper control arms unless I want to go higher? If I go with the fox coilovers, do I need the optional upper control arms then?
Thanks in advance, Dave
FaintReality is offline   Reply With Quote
