Old 07-03-2007, 07:50 PM   #3 (permalink)
rynomx785
rynomx785's Avatar
Re: 7" kit questions
Its gonna sit @ss end high with the 4" blocks that come with the lift. The kit actually only sits 6.5" higher than stock in the front with spacer and stock strut. the upper control arms are to add droop travel not heighth. The fox coilovers will work with the stock UCA but there are better options out there as far as coilovers. You should be able to get the install instructions at cstsuspension.com
