Re: Biggest Trailer for XE Non BT
I have the identical truck (06 XE CC no BT) with the 6500 lb tow capacity. The non-BT LE and SE have a higher towing capacity with the same suspension, gear ratio, etc... and it is my understanding from browsing through the forum that the reason the XE has a lower tow capacity is because of the tires. HOWEVER, since I have installed a class IV weight distributing hitch, thus taking the weight off the rear axle and distributing, wouldn't the max towing capacity of the XE move up to the 7400 lb range?
