Originally Posted by royr
What are they doing for yours - with mine they empied the 1 1/2 pints of filthy type D from the transfer case, tightened up the loose bolt and then refilled it with new nissan D matic. I was concerned about all the metal shavings on the magnetic drain plug - but the service manager and the head mechanic said that was "normal" break in wear on 14,000 mile fluid that had not yet been changed (I was schedualed to change it at 15K service interval. Is this normal - or am I looking to get stuck down the road?
I changed the transfer case oil (and front and rear diff oil), at 1500 miles and at 12k miles on my 05. While I expected the 1500 mile oil to be fairly clean( and it was), the 12k oil also looked like new and there was nothing on the drain plug.
1/3 of my mileage is in 4WD and I shift into and out of 4WD at least 20 times a week.
From my experience, what you described is not normal, my new oil looked the same as the old oil that I changed out, I figured I wasted my money on the oil change.
