Old 07-16-2007, 02:24 PM   #3 (permalink)
Yahooligan
Yahooligan's Avatar
Re: Trans temp lower when in 5th.
Originally Posted by HavaTITAN
Hi, I just installed a digital trans temp gauge. My work trailer is about 2,800 lb's, my truck is an '04 cc xe 2x4. I was on the Hwy last night and noticed if I run in 4th (as I allways have) the temp. reads mid. 140's. Now if I drop it into 5th the temp drops to the low 140's and high 130's. Is it safe to run in 5th on the Hwy as long as the trans temp. stays low or will it hurt somthing towing in 5th ( I use 4th for hill's).
Both of those temps are fine when towing, maybe a little on the low side. Where did you install the temp sensor? You should be reading the temp as it exits the trans and not after the trans cooler or in the pan as both of those locations will give you very misleading numbers.
Heat kills transmissions, as long as the temp is kept within range and the trans isn't constantly locking and unlocking the torque converter then you're fine.
On land: 2005 Titan SE CC 4x4
On sea: 1984 Scarab 21SS - Marine Power 454
Yahooligan is offline   Reply With Quote
