Old 07-16-2007, 03:08 PM   #5 (permalink)
HavaTITAN
HavaTITAN's Avatar
Re: Trans temp lower when in 5th.
Originally Posted by Yahooligan
Both of those temps are fine when towing, maybe a little on the low side. Where did you install the temp sensor? You should be reading the temp as it exits the trans and not after the trans cooler or in the pan as both of those locations will give you very misleading numbers.
Heat kills transmissions, as long as the temp is kept within range and the trans isn't constantly locking and unlocking the torque converter then you're fine.
I put the sending unit in the line going from the trans to the rad. not the return line. The temp is in the 160 to 180 range around town, it's only that low on the Hwy.
HavaTITAN is offline   Reply With Quote
