Re: Fifth Wheel Report
Originally Posted by goldwing
Well no, the trailer is not heavy for a Titan. Have you pulled one? I had a surburban with a 454 engine...it could not hold a candle to the pulling power of a Titan. In fact I was surprised that my MPG was equal if not a bit better than the same truck pulling a 5000# TT. The aerodynamics of a 5th wheel is better than a TT...less wind resistance means less load on the truck. The MPG proves that.
If you notice in my signature I have a 5th wheel and I also double tow with my boat behind the trailer. Check out the what do you tow thread and my rig is listed on the first page a few posts down.
Have you taken your trailer to a truck scale, what are the weights? There is no question that the Titan has the power to pull much heavier loads than it is rated for but the payload is the trucks limiting factor. I am over weight by a 150#'s with a 21' 5th (yes it is heavy for it's size). It's not the going that will be a problem for our truck, if they are overloaded, but the stopping.
2004 Nissan Titan KC SE 4x4 with Big Tow package- Zoomers exhaust tip, Rear-view screen in sunglass pocket, scanguage intergrated into overhead console, power tailgate lock.
1982 Delorean DMC-12 Turbo (Vin #10696)
2000 Toyota Camry CNG Powered
1999 Forest River Sandpiper 21R 5th wheel trailer
