Old 07-17-2007, 10:27 AM   #1 (permalink)
saltydog
rear dif question
i've read most of the dif threads and it appears that most have seals leak @ the wheel hub. has anyone noticed leaks where the dif connects to the axle? no oil drops anywhere in the garage. i'm thinking that the service department may have checked and added oil to avoid a warranty issue with my truck. other than the dif being covered with oil it runs and drives fine.
04 kc 4x4 with bt. do you think it's possibly going to go out like the others or is this hopefully not a problem at all.
thanks
jeff
saltydog is offline   Reply With Quote
