Old 07-18-2007, 09:53 PM   #1 (permalink)
TitanBarry
Problem with towing harness..
My truck does not have a stock Nissan Tow Pkg. At some point a aftermarket harness was put on. By the looks of it tho, my truck had a harness ran to the rear of the truck and just needed the actual 5 pin jack connected.
I bought a new trailer with surge brakes, so it is essential that the brake light/reverse light worked. I started playing with it. I have gotten everything to work except running lights. My brake lights work and both blinks, also my reverse power to disable the brakes.
I did research first, i checked the famous 10 amp fuse, I checked all the fuses. I used a test light and none of the wires coming out of the harness have power when the lights are on. There are I believe 7 wires and out of the three not being used none have power. Does anyone have an idea what my problem could be? Is there a way to check the wiring as to which color wire goes to what. The few I have left are solid red, white (which is thicker and i think has a blue stripe) and one more i believe. Thanks for the help. I am pulling my trailer Next Tuesday and hope to have it all solved.
Barry
TitanBarry is offline   Reply With Quote
