Re: need help with tpms !!
The TPMS are are part of the valve stem. After you break the old wheels down, you use a deep well socket (14mm I think) to unscrew the collar that is on the valve stem. Once you have it completely unscrewed, put the TPMS in the new wheel & put the collar back on & retighten. It's about the easiest thing you will ever do...other than breathing.
I wouldn't worry about changing the gaskets on them unless they're really screwed up.
2006 Granite King Cab SE Big Tow 4X4 w/Utili-Trak. 18X9 Black Pro Comp wheels w/Bridgestone Deuler A/T Revo's. PRG - 2" Leveling Kit. Trifecta Tonneau Cover. 18" Magnaflow Muffler. AVS Bugshield & Ventshades. Air-Box Mod. Pro Comp Lightbar waiting to be installed.
