Old 08-01-2007, 06:42 PM   #1 (permalink)
Treebasher
Treebasher's Avatar
Brake booster replaced, again...
I had an issue in February with the SLIP light and VDC OFF light not shutting off. I brought it to the dealer and $800 later, they replaced the brake booster.
Since then the brake pedal has been rock hard after it sits for a couple of hours. I mentioned this the last time I had the oil changed in March and they replaced a check valve which I thought fixed it but it did not fix the issue.
Today, I brought the truck in for an oil change, seat belt recall, and to have them check out the brake system again. This time they determined the brake booster was defective causing a vacuum leak. The good news is this will be covered under a 1 year Nissan parts warranty.
Another correct debug from bestatchess. Thanks best.
Born on 01/2004
K&N Filter Charger and prefilter...........Stubby antenna
Westin Bull bar.........................................Front tint
PRG leveling kit........................dss90c LED bed lights
Access tonneau cover.................Stainless bug guard
GT seat covers.........................Tailgate assist spring
Husky floor mats.............Tailgate key fob locking mod
Banks "Monster" exhaust.......................Keyless entry
AT grounding kit................................HID headlights
Grille inserts.....................295/70 R17 Nitto Grapplers
Alum. rear diff. cover...........................HID fog lights
next?
Treebasher is offline   Reply With Quote
