Old 08-01-2007, 10:02 PM   #7 (permalink)
Titan5683
Re: Weight information on 17" steel or Off road rim
Originally Posted by GregP
Assume sea level and let's assume your Titan weighs 5,000 pounds and makes 325 HP with the mods you have done.
Using standard drag racing formulas your ET in the quarter mile would be about 14.49 seconds at about 94.1 mph using stan dard techniques.
Now assume you buy the heavier wheels, so your truck weight 5,056 pounds.
Again using standard drag racing formulas your ET would be 14.54 seconds at 93.7 mph using the same standard techniques.
Yes, you went slower, but the ET only got worse by 0.3%!
A good launch technique that results in good 60-foot times will buy you more than that. And that's all I meant to say ... sorry if I implied otherwise.
Good luck with your Titan. Beat the crap out the Tundras! We're already faster and quicker than Chevys and Fords.
I got ya, hopefully I didn't come across the wrong way
05 Titan KC SE - Smoke, BT
Nismo CAI, FlowMaster 40 SI/SO 3", Timing Advance, TB Bypass, 5% tint, Smoked Tails, Armada Lip, De-badged, Silverstar Ultra's.
Best ET 15.32@90.8 2/8/08
Wife's Car: 02 Altima 3.5 SE 5MT - Mystic Emerald Nismo CAI, VIAS Plate Removed, Royal Purple Fluids, Jim Wolf Clutch/Flywheel, Dual Magnaflow w/ OEM Resonator Removed, Nitto NT555 245/45/17, De-badged
Best ET 14.16@100.4 2/8/08
Titan5683 is offline   Reply With Quote
