Re: What I get for showing off!
E Brake activates a brake pad on the rear axle (not the normal brakes if I recall correctly), so it was a scorching of brake pads that you heard. Don't worry about it. If they still work fine, it's OK.
Drum brakes usually have a small and a large shoe, the small shoe is the E brake. On disc, sometimes a second hidden set of pads holds it(more inboard), or the main pads.
2006 XE CC Pref Pkg BT with AEM Brute Force CAI, PowerAid TB Spacer, TB Reversed Valve ByPass Mod, 2007+ Intake, JBA Headers, MagnaFlow 24" Muffler, 2008+ Rear Axle, Stillen: F & R Sway Bars, Black Diff Cover, Engine Dress Up Kit, 4 pc StreetScene SS Mesh Grille, PRG Street Traction Bars and Mini Lift Kit, UpRev Osiris Tuner 93 Performance Tuned, MB Razor Rims, Functional Hood Scoop, Custom Graphics ...
