Re: how much can I pull
The most significant difference between BT and Non-BT is the lower gears, which adds to the added towing capacity (9400lbs). In answer to the first post, the truck should be fine with those weights.
Towing guide is here also, in case you don't have it:
http://www.courtesyparts.com/titan/towing.html
2006 XE KC 4x4, Galaxy Black
Preferred Package, OEM Bug Deflector
Sirius Satellite Radio / IPOD (Plug in kits)
AMSoil 5W-30XL Synth. Motor Oil, OEM Oil Filter
AMSoil Drop in dry air filter/Air Box Mod
AMSoil 75W-140 Severe Gear Rear Diff Fluid
Mobil 1 75W-90 Synthetic Front Diff Fluid
Toyo Open Country AT's P265/70/17
