Old 08-23-2007, 12:17 PM   #4 (permalink)
bvstone
Re: Brakes going bad again.. Ugh!
So I finally found the right TSB with part numbers...
The 2nd time they did my brakes the DID install the proper new rotors, but that is all, they didn't do the rest which is new pads all the way around, resurfacing rear rotors. The other parts on the TSB were replaced on the first fix they did where they just resurfaced (bolts and stuff, new pads but the older style). But the pads with the rotor replacement have different part numbers than the old ones.
SOOO..... they MESSED up if you ask me... you can't just slap on the new rotors with the old pads!
bvstone is offline   Reply With Quote
