Re: overheating problem,,,HELP!! :)
I have not looked at my titan, but on my little mazda truck it has a similar radiator setup. Since the radiator does not have a cap, the recovery bottle is pressurized and it always has some antifreeze flowing back into it.
There is a problem if the truck is overheating...either a fan, low coolant, thermostat, or serious head gasket problem.
I would check the antifreeze level..if you are losing coolant, fix it.
I don't really think a broken electric fan would cause overheating unless you were towing or really working the engine...but that fan is easy to check..either it works or it doesn't.
