Originally Posted by jasonwabc
I have not looked at my titan, but on my little mazda truck it has a similar radiator setup. Since the radiator does not have a cap, the recovery bottle is pressurized and it always has some antifreeze flowing back into it.
There is a problem if the truck is overheating...either a fan, low coolant, thermostat, or serious head gasket problem.
I would check the antifreeze level..if you are losing coolant, fix it.
I don't really think a broken electric fan would cause overheating unless you were towing or really working the engine...but that fan is easy to check..either it works or it doesn't.
it's not the fan,,,it works,,,taking it to the dealership tomorrow,,,hopefully it will be something simple and fast,,will post on here when i return,,,,thank you for your help!
