We have some
killer deals on our VORTECH SUPERCHARGERS!
The kit includes everything you need, unichip computer, blower with brackets, air to water intercooler. this is the same kit that made
420 hp/450tq on our own TITAN truck!!
Complete and ready to run!
Each Vortech supercharging system is designed, tested, and sold to be installed on vehicles in their original or otherwise stock form. They are engineered to deliver maximum performance and long-term engine durability at safe boost levels on stock engines. By taking into consideration variables such as the intended use, climate, altitude, and design parameters of stock engines, Vortech supercharging systems deliver proven performance.
Included components:
* CW rotation SC-trim supercharger uses 3.0” 7-rib pulley.
* Air/Water charge air cooler increases performance and reliability of supercharger system.
* Plug and play “Piggyback” ECU controls ignition timing and fuel enrichment.
* Fuel system upgrade includes larger in-tank fuel pump
* Larger Fuel Injectors
* Supercharger drive system includes all necessary belts and pulleys.
* Billet aluminum plate mounts supercharger and has integral oil drain (no drilling required).
* High flow air filter and “cold air” inlet ducting reduce pressure drop and intake air temperature.
* Oil drain and oil feed assemblies allow for maintenance free operation.
* Allows retention of all vehicle accessories.
* CARAllows retention of all vehicle accessories.B E.O. D-213-25
* Installation time is 14-20 hours.
PM me for our killer prices!!
Matt
