Old 08-27-2007, 06:25 PM   #5 (permalink)
TitanicDJ
TitanicDJ's Avatar
Send a message via MSN to TitanicDJ
Re: Maximum suggested trailer length?
Mine is just over 30' and about 7500 lbs. loaded. I know that there are a few that actually tow longer and heavier but this is big enough for me. IMO, I wouldn't go over that with out getting a 3/4 ton. You should make sure what ever you get that you also invest in a good set-up. Get a good WD hitch like the Equal-i-zer hitch and brake controller, like a Prodigy. I'm also a firm believer that you don't max out the 9500 lbs towing rate but do the 80% Rule just to play it safe.
All in all this truck is a great tow vehicle even with the lift!
'04 White SE, CC, BT, Off Road 4x4
• Banks Monster Exhaust • Pro Comp 6" Stage II • PRG Radflo External Reservoir Coilovers w/King Springs
• PRG OR Traction Bars • American Racing Chamber w/Teflon 17" • BFG T/A KO 315/70 17 • Active Tuning Grounding Kit
• FramBoost Air Intake • XM Satellite Radio • Hoppy Assist Tailgate • Grillcraft Black Mesh Grille • 2° Timing Advance
________________________
TitanicDJ is offline   Reply With Quote
