Old 08-27-2007, 07:05 PM   #3 (permalink)
Bassin Bob
Re: Four Wheel Drive
Originally Posted by jaho1979
When driving in 2wd, the front half shafts, diff and driveshaft are all spinning. 4wd engagement happens in the transfer case. This drag, along with added equipment weight contributes to decreased fuel economy over 4x2's.
The reason for my question is I have had a drivshaft disconnect kit (Remco) installed on my truck so that I may tow it behind my motor home. By disconnecting the rear driveshaft I think I should be ok. If the front shafts are turning all the time it should not make a difference as far I can see.
Any comments?
07 CC 4x4 LE Off Road, Silver, loaded, Magnaflow Exhaust
Bassin Bob is offline   Reply With Quote
