Re: KMC rockstars centercap on 18" question
I have the 2" front leveling kit on a 4wd. I'm not sure if the 4wd sits higher then the 2wd.
The tires are Nitto Terra Grappler 325/60/18
They do rub a bit but only in reverse. I will need to do the pinch weld mod. I'm just looking for a cheap heat gun.
I'll have to get back to you on the wheel specs as they ordered these directly from KMC. No one had the Size for the Titan so they had KMC drill out a set for me.
What I can tell you is they are 18x9. They do stick out about an inch though.
You shouldnt have a problem with your 22's It only affects the 18s. I just ordered some shorter allen bolts today. I went everywhere but no hardware store carries metric allen bolts, go figure.
FYI: When you get yours check the little "XD" emblem stickers on one of the arms. I lost 3 out 4 in a car wash. I said the hell with it and just tore the last one off.
KMC ROCKSTARS 18X9 0 OFFSET 5.5" OF BACKSPACING
TIRES NITTO TERRA GRAPPLER 325/60/18
2" LEVELING KIT WITH PINCHWELD MOD.
