Re: Cargo Light???
It depends on how you want it to come on! If you want them to come on when the door is open, then just pull the power off of the dome light and get the ground from the door pin switch, or if you want the to come on with the dome lights, then just pull the porwe aqnd ground off of the dome light. You could also just make your own switch on the dash by using one of the kc light switches. Anyway, thats my thought!!
-Jamie
