Old 08-28-2007, 01:40 PM   #11 (permalink)
dragonhead08
dragonhead08's Avatar
Re: KMC rockstars centercap on 18" question
You'd think that, but I guess they decided to make things interesting. Because of that I had to special order the bolts and turned out to $40 for stainless steel.
FYI: wheels are 18x9 6lug 5.5 backspacing.
Also they'll need to use different o-rings. The Rockstars valve hole is drilled out too big to use the tps without new rings. Te guys at america tire pilfered from a different kit they had on hand. 2flat tires later I hope they have it down. oh well, **** happens.
New pics
two of the close ups shot reference images.
The center cap has posts that I cut off 1.25" using new socket bolts that were sized m8x50. I painted them primer black
the rear shot shows how much they stick out.
KMC ROCKSTARS 18X9 0 OFFSET 5.5" OF BACKSPACING
TIRES NITTO TERRA GRAPPLER 325/60/18
2" LEVELING KIT WITH PINCHWELD MOD.
dragonhead08 is offline   Reply With Quote
